Resonant Frequency of a Cantilever
The discussion revolves around calculating the resonant frequency of a cantilever beam in the context of an experimental setup where a spray force is applied. Participants explore how to ensure that the applied force does not induce oscillations at the beam's resonant frequency, which could lead to inaccurate displacement measurements. The conversation includes theoretical considerations and practical implications related to the setup.
  • One participant, Mistry, seeks guidance on calculating the resonant frequency of a cantilever beam to avoid inaccuracies in displacement measurements due to oscillations.
  • Another participant, CS, provides a formula for the natural frequency of a cantilever beam with a load at the free end, suggesting it could help determine appropriate dimensions for the beam.
  • CS also notes that the spray itself does not have a resonant frequency, but it may act as a constant distributed force or a periodic force, which could affect the beam's response if its frequency coincides with the beam's modes.
  • There is a request for the source of the formula provided, indicating a desire for further exploration of the topic.
  • CS mentions that the equation can be found in vibrations or strength of materials textbooks, specifically citing Roark's Stress and Strain as a source.
Participants generally agree on the importance of understanding the resonant frequency of the cantilever beam and the nature of the forces involved. However, there is some contention regarding the characterization of the spray force and its potential effects on resonance, with differing views on whether it can be treated as having a resonant frequency.
The discussion does not resolve the complexities of how the spray force interacts with the cantilever beam's dynamics, nor does it clarify the assumptions behind the provided formula. The implications of the spray's characteristics on the overall system remain uncertain.
mistry
Hi
I'm currently setting up a simple cantilever beam experiment. The cantilever will be positioned vertical and a spray force will be exerted from the left hand side, causing the plate to deflect. This deflection will be measured and recorded.
My question is how do I calculate the resonant frequency of this cantilever? I need to make sure that the force exerted does not cause the plate to oscillate at its resonant frequency and hence output inaccurate displacement values. If I can find this out I could possible determine an adequate thickness and length before making it.
Similarly, the force exerted will be from a spray. Is there a way of calculating the resonant frequency of the spray on the plate, to ensure I do not reach this point and hence obtain inaccurate values.
Thank you in advance
Mistry
mistry said:
Hi
The natural frequency of a cantilevered uniform beam (with negligible beam weight) with a load on the free end is given by:
[tex]f_1 = \frac{\sqrt{3}}{2\pi}\sqrt{\frac{EIg}{Wl^3}}[/tex]
Not sure on this part. However, what you might do is determine the reaction force of the spray impinging on the beam and then use that to get your theoretical deflection. It may give you some idea as to whether or not your results are skewed by resonance.
Hope this helps.
CS
The spray itself will not have a resonant frequency. Only bodies have a resonance (in this sense of the word). The spray will act as, most likely, a constant distributed force. In the worst case it would be a periodic force of some kind that would then be a forcing function. So your concerns of resonance will center around the frequencies you calculate for the beam and hope your spray's frequency (if there is one) doesn't coincide with one of the beam's modes.
Hi
Thanks for your responses. In order for me to look into this further, 'stewartcs', can you tell me where you got the equation from or from which book?
Thanks
mistry said:
Hi
Thanks
Any vibrations book will have that equation in it (or even a strength of materials book). That equation was specifically from Roarks Stress and Strain.
CS
  • · Replies 22 ·
  • · Replies 21 ·
