Rotational Energy Homework - Calculate Moment of Inertia & KE
The discussion revolves around calculating the moment of inertia and rotational kinetic energy for a dancer spinning at 72 rpm. The participant uses the solid sphere and solid cylinder equations to compute the moment of inertia based on their body mass distribution: head (7%), arms (13%), and trunk and legs (80%). Initial calculations for the moment of inertia yield a total of 65190, but the participant later realizes an error in their approach. The focus is on applying the correct formulas and measurements to achieve accurate results. The conversation highlights the importance of careful calculation in physics problems related to rotational motion.
bkl4life
A dancer spinning at 72 rpm about an axis through her center with her arms outstretched. The distribution of mass in a human body is
Head: 7%
Arms 13%
Trunk and legs: 80%
Using your own measurements on your body calculate your
a) moment of inertia about your spin
b) rotational kinetic energy
I decided to use two equations: the solid sphere and solid cylinder
I=2/5 MR^2
I=1/2 MR^2
75 kg for weight, 10 cm for head, 60 cm for arms, 90 cm for trunk.
.07*75=5.25
.13*75=9.75
.8*75=60
Head: 2/5*(5.25)(5)^2=52.5
Arm: 1/2*(9.75)*(30)^2=4387.5
Trunk: 1/2(60)(45)^2=60750
I add those up and got 65190I'm not sure if I did this right.
Never mind, I saw what I did wrong!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
