Biot Savart Law with a surface current
OmarRod
There is a disc with radius R which has a uniformly-distributed total charge Q, rotating with a constant angular velocity w.
(a) in a coordinate system arranged so that the disc lies in the xy plane with its center at the origin, and so that the angular momentum point in the positive z direction, the local current density can be written J(x,y,z) = K(x,y) d(z). determine the surface current K(x,y) in terms of Q, w, and R.
(b) using the Biot Savart law, determine the magnetic field at point r=sk, k is the vector direction. find the same for r=-sk.
Biot Savart Law
I obtained K= Q(w X R) / pi*R squared for part A, but I'm not sure how that's supposed to fit into the Biot Savart Law.
Note that the velocity of the current is not equal for charges at R/2 as it is for charges at R (the angular velocity is the same, but the radii are different). Try modeling the solution as a sum of current loops of width dr, with approximately equal radius (and thus velocity)
This answer would then be the current, which can be modeled with the Biot-Savart law.
~Lyuokdea
Ok, I've done this and after applying Biot Savart's Law, I get a zero magnetic field. This can't be right can it?
that doesn't sound right...what did you get for J, and how did you include this into the biot savart law?
~Lyuokdea
nevermind, i looked at it again and found my mistake. thanks!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
