How to Calculate Flow Rate with Given Parameters?
The discussion focuses on calculating the flow rate of water fed from a tank 12 meters above ground through a 200-meter long pipe with a diameter of 125mm. The friction factor is specified as 0.008, and the K factors for fittings total 3.3. The approach involves equating the potential energy from the height (ρgh) to the kinetic energy of the flowing liquid (1/2ρV²), while also accounting for frictional losses using the formula: Frictional resistance energy loss = ½ ρ*f (L/d) x (V²) and the additional losses from the K factor. A relevant lecture is provided for further understanding.
  • Understanding of fluid dynamics principles
  • Familiarity with Bernoulli's equation
  • Knowledge of friction factor calculations in pipe flow
  • Basic grasp of energy loss in fluid systems
  • Study Bernoulli's equation and its applications in fluid mechanics
  • Learn how to calculate friction losses in pipes using the Darcy-Weisbach equation
  • Research the significance of K factors in fluid systems and how to calculate them
  • Watch the provided lecture on fluid dynamics for practical insights
Engineers, fluid mechanics students, and anyone involved in hydraulic system design or analysis will benefit from this discussion.
Sevy35
I'm trying to get my head around this question but having missed a few lecture through illness I'm going round in circles.
Water is fed from a tank 12m above ground along a pipe 200 m long with a diameter of 125mm. Pipe frictyion factor is 0.008. K factors for the fittings, (tank exit, valve etc) add up to 3.3. I'm being asked to find the flow rate in kg/s and donlt knwo where to start.
I don't want the answer, just some direction of how to approach it.
Regards
Sevy.
Welcome to PF.
Basically you are going to have the potential energy of the drop (12m) that is given in ρgh that will go into kinetic energy of the flowing liquid that will be 1/2ρV².
But that's not all it goes into because they have given you the frictional factor that will be experienced over the 120m of run length. And you have the K factor for the pipe system that takes into bends and such that they would give you of 3.3.
The contribution to friction loss I think looks like
L is Length and d is diameter and f is your frictional factor.
The K factor contributes an additional energy loss of ½ ρ*K*V²
where K is your K factor.
Here is a lecture that touches on some of the basics. (About 30 minutes in.):
https://www.youtube.com/watch?v=ngABxM7jl0Q
  • · Replies 30 ·
