Optimizing Area for a Sport Center with a Rectangular Region and Semicircle Ends
david12
help me out on this proble i am confuse
a sport center is to be constructed.it consists of a rectangular region with a semicircle ach end .if the perimater of the room is to be a 500 meter running truck find the dimetion that will make the area as large as possible.
i can find if the picture only has a rectange.but the perimater of the half circle which is pir^2
p = 2lw + PI r
500=2lw + pi r
i don't know where to go after this please help me out
Hmm you can use Lagrange multipliers to solve this but it may be unnecessary. Otherwise you can just find the values of l,r (note that w=2r) such that Area is maximised. You wrote p when it should meant Area instead. So find the stationary points of the function A(r,l) and check which is a max point.
p = 2lw + PI r
No. First, the perimeter of a rectangle is 2l+ 2w, not "2lw" (you are mixing perimeter and area formulas). Also if you run around the half circle you do NOT run along that end of the rectangle. Taking the semi-circle to be on the "w" end, the distance is 2l+ w+ pi r.
500=2lw + pi r
500= 2l+ w+ pi rl. Also, have you drawn a picture of this? Is so you should have been able to see that the semi-circle has one end (w) of the rectangle as diameter: r= 2w.
You want to maximize the area. What is the formula for the area, as a function of l and w? You can use the perimeter formula to eliminate one of the variables.
Edit: Does "with a semicircle ach end" mean a semi-circle at each end? That makes more sense! I was wondering about runing around the corners! In that case, there is no "w" length so the perimeter is 2l+ 2pi r. And, of course, since we now have an entire circle added the area is lw+ pi r^2= 2lr+ pi r^2.
What does 'lw' mean? The perimeter of a semicircle is pi*r (not pi*r^2), but there are two of them in the perimeter. You'll really need to be a lot clearer about what you are doing. Once you said what all the symbols mean, what's a formula for the area?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
