Pendulum collision and elastic collision
The discussion revolves around a physics problem involving two pendulums that collide and either stick together or undergo an elastic collision after being released from rest at an angle. The key equations to consider are the conservation of energy and momentum. The first step is to determine the velocities of both pendulums just before the collision, which occurs at the lowest point. After the collision, the combined mass's velocity can be calculated to find the height it will reach and the final swing angle. The conversation emphasizes the need for a symbolic solution and encourages breaking down the problem into manageable parts for clarity.
ihateap
1. Homework Statement
2 pendulums collide and stick together after being released from rest at angle Ø (each one is at Ø)
pendulum 1 mass is 2m, pendulum 2 mass is m
What is the final swing angle of the stuck together masses? in what direction is the swing?
repeat for elastic collision
2. Homework Equations
Ui+Ki+Win-Wout=Kf+Uf (conservation of energy)
conservation of momentum
3. The Attempt at a Solution
a very sad one
sorry i couldn't put a picture up, even though it would help a great deal
but any suggestions would help
and if you couldn't tell it has to be solved symbollically
They will collide at angle phi=0 (the lowest point on the pendulum), right? What is the velocity (and hence momentum) of each pendulum just before they collide? If they stick together, then after the collision you have a single object with the same momentum. What's it's velocity? Translate that into to how high it will go, and what the angle is. Try and start answering some of these questions. It will make for a much improved 'attempt at a solution'.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
