Challenge question for physicists
The discussion centers on the buoyancy of a hypothetical balloon filled with air and possessing infinite hardness. It argues that the balloon will float if the upward buoyant force, created by pressure differences on its surfaces, exceeds the downward gravitational force acting on its mass. The hardness of the balloon does not affect buoyancy calculations, as gravity operates independently of the balloon's structural properties. Practical examples, such as submarines, illustrate that buoyancy relies on pressure differences and gravity rather than the interaction between water and the balloon's contents. Ultimately, the key takeaway is that buoyancy is determined by pressure and gravity, not the hardness of the object.
gunslingor
Okay, I have been wondering this for a long time. The question concerns buoyancy of objects in water.
Question:
Imagine you have a balloon filled with air. Imagine the balloon has virtually zero mass, but actually has a virtually infinite hardness. You could replace the balloon with a force field or sorts, like star trek. So, will the hypothetical balloon float? The arrangement in itself would have less mass than water; so by this reasoning it will float. But it has infinite hardness and therefore cannot bend in the expected way (if you were to hold a real balloon by the filling point underwater, it would stretch out as you go deeper and deeper). So the water can have no direct or indirect interaction with the mass inside the balloon. So will the balloon float? If not, has as hardness been accounted for in buoyancy calculations?
I don't understand the issue. Why wouldn't it float? The calculation of buoyant force does not require any "bending" of the object.
Hardness, or interaction with the contents of the balloon are not relevant.
1. The pressure exerted on the top surface of the balloon is smaller than the pressure exerted on the bottom surface (because the top surface is at a smaller depth where the water pressure is smaller). This difference in pressures depends only on the density of water and the geometry of the balloon, and it gives rise to an upward buoyant force.
2. If this upward force exceeds the downward gravitational force on the balloon (determined by the mass of air in it), the balloon will float.
So the water does not need to interact with the insides of the balloon, only gravity does. And gravity doesn't care about the hardness of the balloon shell.
As a practical example, consider a submarine - essentially a steel balloon that is capable of floating.
Dah, I think I'm an idiot, lol. You explain it very well, which braught back a lot of examples from physics I had forgotten. For some reason, I think I had made the assumption that gravity couldn't interact with the balloon mass internal; I assumed that the waters interaction with gravity was the only effect.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
