Time Travel and Conservation Laws
TheBaker
I'm doing some research into time travel for a presentation I have to give in a month or so, and I'm currently looking at the compatibility of Time Travel and the Laws of Conservation.
Sending an object back in time would increase the mass - and hence the energy - in the Universe at this time, and would therefore appear to violate the conservation of energy.
However, I found http://www.weburbia.com/physics/time_travel.html" that says that in fact the conservation laws may not violated because conservation laws are local, whereas there may not be a global conservation law.
I've tried to find more information on this, but couldn't nothing obvious came up, so I was wondering what people here thought of the idea.
Assuming that there are no other objections to time travel, do conservation laws necessarily rule out time travel? Or can the two be compatible (even if it requires something strange to be happening)?
Here's a good page on the problems with defining what "energy conservation" means globally in general relativity (and general relativity does allow for the possibility of backwards time travel in certain unusual spacetimes):
http://math.ucr.edu/home/baez/physics/Relativity/GR/energy_gr.html
It would have more mass i think when it speeds up to allow it to go back in time but as soon as it stops it would have the same mass. Asumeing nothing interfears. If it did make it back in time we wouldn't see it because events in time would change it. But it would have more mass at the objects initial entry in time.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
