Basics of pressure and pascal's principle
The discussion centers on understanding how pressure, depth, and height affect force in fluids, specifically through Pascal's principle. The original poster seeks clarification on whether increasing volume and height in a fluid leads to greater force generation at deeper levels. They suggest that an initial input force can multiply due to these factors, resulting in a greater output force at increased depths. A participant questions the specifics of the fluid's containment, indicating that the setup may influence how force is transmitted. The conversation emphasizes the importance of the underlying principles of fluid mechanics in understanding these dynamics.
johndb
I've being studying fluids and pressure, but want to clarify something. Take a rough example of a force applied on a fluid/gas is it correct to say that from 'P + pgh' one can say that as the volume and height increases or with these increasing layers there is more force been 'packed' behind /generated with the greater depth and from the receiving end a greater output in terms of force with each increase of depth directly vertically below the applied force (ignoring where pressure gauges often channel forces horizontally away and then opposite in direction up an exit pipe which balances forces, e.g. barometer or manometer). In a sense can I say that because of depth, height and pressure an initial input force can increase/multiply because of these factors for a greater output force.
johndb said:
I've being studying fluids and pressure, but want to clarify something. Take a rough example of a force applied on a fluid/gas is it correct to say that from 'P + pgh' one can say that as the volume and height increases or with these increasing layers there is more force been 'packed' behind /generated with the greater depth and from the receiving end a greater output in terms of force with each increase of depth directly vertically below the applied force (ignoring where pressure gauges often channel forces horizontally away and then opposite in direction up an exit pipe which balances forces). In a sense can I say that because of depth, height and pressure an initial input force can increase/multiply because of these factors for a greater output force.
I'm not clear as to what exactly you are asking. Is the fluid in a rigid container, a cylinder/piston assembly, or something else?
CS
Well I'm not fussy, can be any of those, (unless of course that changes how the the force is communicated through the fluid/gas) I'm concerned about the underlying principle.
Perhaps this will help:
http://hyperphysics.phy-astr.gsu.edu/Hbase/pasc.html
CS
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
