Can Immersion in a Liquid with Equal Body Density Mimic Zero Gravity Experience?
Immersion in a liquid with equal body density does not replicate the zero-gravity experience due to the physical interactions of internal organs. In microgravity, organs float freely, while in a neutral buoyancy environment, they still exert pressure against the body. Circulation and respiration also differ significantly between the two settings. Neutral buoyancy tanks, like those used by NASA, simulate microgravity for astronaut training but involve movement through a viscous fluid, which is not present in true zero gravity. Overall, while there are similarities, the experiences are not identical.
kky
Suppose I prepare a liquid whose density is equal to the average density of my body.
Hence when I am completely immersed in it the upthrust provided will be equal to my weight. Will what I experience in such a liquid be similar to what I'll experience in zero gravity?
Not really. I'm no expert, but your various organs would still impede upon your body as normally. In micro-gravity (there's no such thing as zero-g), the organs would be free-floating within your body. You would still feel, for instance, your intestines and liver pressing against your back in an SD tank, but not in free-fall. Circulation and respiration would similarly behave differently in the two environments.
kky, what you describe is indeed used to simulate ug conditions for astronaut training- NASA has a few giant swimming pools (neutral bouyancy tanks):
http://en.wikipedia.org/wiki/Neutral_Buoyancy_Laboratory
As Danger points out, this is not exactly the same as ug conditions. Another trade-off is that the astronauts have to move through a viscous fluid which is not normally present. However, neutral bouyancy tanks are useful for training situations that require periods of time longer than the 20 seconds achieved on the 'vomit comet'.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
