Normalized Current in Transmission Lines Explained
  • Thread starter Thread starter swty todd
    Current
Normalized current in transmission lines refers to the current divided by the square root of the characteristic admittance, while normalized voltage is the voltage divided by the square root of the characteristic impedance. These concepts are essential for analyzing waveguides and transmission lines, as they simplify calculations and comparisons. Normalization helps in understanding the behavior of signals in these systems. The discussion clarifies that these terms are related to division but serve specific purposes in electrical engineering. Understanding these definitions is crucial for effective transmission line analysis.
swty todd
in transmission lines i came across words such as mormalized current and normalized voltage...what do they mean..does it hav nething 2 do wid division??
Hi swty todd! :smile:
From http://www.answers.com/topic/normalized-current
The current divided by the square root of the characteristic admittance of a waveguide or transmission line.
From http://www.answers.com/topic/normalized-voltage
The voltage divided by the square root of the characteristic impedance of a waveguide or transmission line.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
