How Does Changing the Air Gap Affect the Energy Stored in a Capacitor?
  • Thread starter Thread starter hellogirl88
    Capacitor Energy
hellogirl88
A capacitor is completely charged with 650 nC by a voltage source that had 375 V.
The initial air gap of the capacitor above was 7 mm. What is the stored energy if the air gap is now 11 mm?
Has the voltage source been disconnected before increasing the distance?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
