Solving River Flow Velocity: A Motorboat Problem
The problem involves a motorboat traveling downstream and later turning back to pass a raft 6 km from the starting point after 60 minutes. The raft moves at the speed of the river, while the boat maintains a constant speed relative to the water. To solve for the flow velocity, one must establish equations based on the boat's speed (v) and the time taken for the return journey (T). The discussion emphasizes the importance of understanding the relationship between the boat's speed, the river's flow, and the distances involved. A clear approach involves setting up equations to express these variables effectively.
abhikesbhat
A motorboat is going downstream overcame a raft at a Point A; t=60 min later it turned back and after some time passed the raft at a distance l=6km from point A. Find the flow velocity assuming the duty of the engine to be constant.
Average Speed,Displacement, Average Velocity
I drew a picture and got confused. I think I don't understand the question.
Hi abhikesbhat! :smile:
The raft is moving at the same speed as the river.
The boat is moving at a fixed speed relative to the river.
Call that fixed speed v, and the time for the second part of the boat's journey T, and write a couple of equations for v and T. :smile:
