How Can You Determine the Capacitance Needed for a Single Phase Capacitor Motor?
To determine the capacitance needed for a single-phase capacitor motor, factors such as starting torque and line frequency are crucial, as they influence the motor's inductance and performance. The capacitor provides a phase shift for the starting coil, allowing the motor to start effectively. The discussion highlights that if a motor runs at 2000 RPM and draws only 1A at 230V, it may not be an induction motor, as this setup suggests unrealistic efficiency. A recommended resource for further reading is Audel's "Electric Motors." Understanding these principles is essential for calculating the appropriate capacitance for motor operation.
GuitarWill88
Hi guys, I have a question about working out the capacitance of a capacitor.
I am not great at electronics, but if i understand correctly the capacitor in a capacitor motor is what makes it start spinning.
I'm wondering is anyone could recommend a good resource for reading about how this works.
I also have a problem that people may be able to help with. I have a motor that runs off 230 mains voltage and draws 1A. It has a horse power of 1/3 and has a speed of 2000rpm.
Is it possible to work out the capacitance of the capacitor in this circuit to start the motor (if so how). If not what do i need to know to work this out.
This is only a hypothetical question and i am not building a motor to work.
Thanks guys,
Will.
The capacitance depends on a lot of different things. Starting torque and line frequency would be the two big ones. Other things which would affect it would be the general design of the stator and rotor. Stator and rotor design will determine how much inductance that 'appears' to the line when 'looking into' the stator winding at zero RPM. Of course this all determines how much starting torque the motor has so like I said, the 2 big ones are starting torque and line frequency.
In a single phase capacitor start induction motor, the capacitor in series with the starting coil provides a phase shift so that the current in the starting coil is out of phase with the current in the main coil. The less expensive split phase induction motors use a very resistive starting coil to shift the phase in the starting coil. The best fractional horsepower motors were the repulsion start induction motors, because the starting torque is high, and the starting surge current is low. My 1/8 HP repulsion-start motor has a patent date of 1915. These were relatively expensive motors, and were phased out when inexpensive start capacitors for FHP motors became available.
I book I use is Audel's "Electric Motors" book, available thru Amazon or eBay.
If your 230 volt motor runs at 2000 RPM, it is probably not an induction motor. Is it single phase or three phase? If it is three phase, it does not use a start capacitor. If you can get 1/3 HP out of 230 volts single phase at 1 amp, its efficiency would be over 100%.
Good point. I completely missed that.
746 Watts per HP. Looks close to me.
But where does the 2000 RMP come from?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
