Find the number of bits that can be stored on a 10cm disk
  • Thread starter Thread starter dirtdawg
    Bits Disk
dirtdawg
A computer disk is made by focusing light to a spot whose diameter is comparable to the optical wavelength. Find the number of bits that can be stored on a 10cm diameter optical disk using an infrared laser.
Lamda λ = diametre of laser
I started by investigating the way this works. A disk would be pressed and it will display pits and lands. Each pit width is 500nm and the land witdth would be 1.6micrometers. As the laser reads each land and pit it will interpret each land and pit as a bit 0 and each transition between land and pit as a 1 bit. Since the laser will cover the same length as its wavelength I tried to find how many pits and lands I could fit under that length (this is about 780nm for an infrared light.
Im thinking I am going about it the wrong way. any ideas?
Hard to say if you're over-thinking it by analyzing the way it works. [Caveat: I don't know how these questions work] but it seems to me there's lots of room for intrerpretation, and thus a range of correct answers. As long as you show your rationale at each step and follow it through to the answer, it seems you'd get a valid, defensible answer.
At its simplest, it's just a matter of how many 500nm spots you can fit on a disk of that width.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
