Potential Energy in Fuels: How Does a Fully Charged Battery Measure Up?
A fully charged 15.0 kg lead-acid battery can deliver 1450 W for one hour, equating to a total energy output of 5,220,000 J or 5.22 MJ. To find the energy per kilogram, this value is divided by the battery's mass, resulting in approximately 0.348 MJ/kg. In comparison, gasoline has a heat of combustion of about 44 MJ/kg, highlighting the lower energy density of lead-acid batteries. The discussion emphasizes the importance of understanding energy outputs when comparing different fuel sources. This analysis aids in evaluating the efficiency and practicality of battery technology versus traditional fuels.
aaronb
A fully charged 15.0 kg lead-acid battery can deliver power 1450 W for 1.0 hr. (For comparison, the "heat of combustion" of gasoline is about 44 MJ/kg.)
Battery _____ MJ/kg
Unit conversion problem
1W = 1 J/s
(1450 J/s / 15kg) = 96.7/10^6 = 9.6 *10^-5
How many Joules is 1450W times 1 hour ?
