Rev Counter Problem need info on a signal divider
The discussion revolves around a rev counter issue after swapping a car's engine from a 4-cylinder to a 2.5 V6, resulting in an incorrect RPM reading due to different pulse outputs. The user reports that the new engine produces three pulses per revolution compared to the previous two, leading to an overestimation of RPMs. Suggestions include changing the ECU memory chip to match the new engine for better performance and using CMOS components to manipulate the signal: first multiplying the frequency and then dividing it appropriately. Specific components recommended include a CMOS 4070 XOR for pulse multiplication and a CMOS 4017 counter for division. The user expresses a lack of electronics knowledge, emphasizing the need for clear diagrams to implement these solutions.
Drisruptor
Hi
i know that this is probably not the best place to look for help but i have been to a lot of forums with no real result . The problem i have is that we changed the motor on my car form a 4 cyl 2l witch gave me 2 pulses per revolution to a 2.5 v6 but this motor gives 3 pulses . its form a separate wire from the ECU . the only other info i have is that the signal does not come from the coil on the car , at idle the signal is 25 Hz and above 2500 rpm its 125Hz . to give a idea how mutch its over reading with the old motor at 120km/h in top gear it was sitting at about 3500 rpm , same speed on new motor its about 5500 rpm . the info i got was that i need to divide the signal by 1.5 and that Possibly a 4046 cmos part with x4 output and a bit of logic to divide it back down by 6 would do the job.
The main problem is me because i never had a chance to learn about electronics , the only time i can build something is if i have a diagram :redface: .
Thank You for your time
Drisruptor said:
Hi
Welcome to the PF. It might just be simpler to change the memory chip in the ECU to the one that matches the new engine. Is that a possibility? Probably get better performance with the correct ECU chip as well.
I think you can do it with two chips. First, you want to multiply by 2. Use the CMOS 4070 exclusive OR (XOR), and put the input signal into two inputs of the same exclusive XOR, with one signal delayed by say 100 microseconds by using an RC delay circuit. Each input pulse in will then give two pulses out, separated by 100 microseconds. Then to divide by 3, use a CMOS 4017 one-of-ten decade counter, and use the "3" output to reset the counter (you may have to invert the signal by using one of the unused XORs), the reset signal will then be a divide by 3. You may want to buffer this output with a transistor. You may also want to use a one-shot (monostable) to stretch the output pulse.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
