What Experiments Can Prove Light and Wavelength Theory Using TCS230?
The discussion focuses on experiments using the TCS230 color sensor to explore light and wavelength theory. Initial experiments included testing the sensor with fluorescent light and LED illumination, demonstrating principles like Fermat's principle and Lambert's cosine law. Participants seek further experimental ideas to maximize the sensor's potential, particularly regarding illumination and surface interactions. There is clarification that the TCS230 outputs frequencies based on color light illumination rather than converting light to frequency. Additionally, users are encouraged to consult the data sheet for detailed information on the sensor's operation and spectral responsivity.
thavamaran
Hi guys, i been recently implementing TCS230 for my final year project, so i have did few experimental stuff on TCS230 and applied few theory for the methodology, first experiment was TCS230 without LED illumination and with just fluorescent light illumination, i got some result and it was not good and i prove it with Fermat's principle, then i did experiment with LED illumination and i prove the theory with lamberts cosine law. I am planning to do more experiment with TCS230 and prove some of light or wavelength theory, what kind of experiment can i do?
Since TCS230 output is frequency base, can i calculate the wavelength with c=f.lamda? is all the visible color has the same speed of light? This particular TCS230 has internal light to frequency converter, i can't find any info on this particular device, how actually it works? please help me, i have tried research across net and books, but i can't really find any reliable source for all this question, please do help me.
Welcome to the PF. From a quick google search, the TCS230 is an RGB photodiode converter to a frequency output signal. Looks to be for light level sensing and color sensing.
Fermat's principle has to do with refraction of light, and would seem to be unrelated. Lamber's Cosine Law relates to reflectance off of surfaces (gotta' love Wikipedia.org). What exactly do you want to do? And yes, the speed of light in a vacuum and in air is the same for all colors. There are some media that are dispersive, but you will probably not run into that in your experiments.
Hey berkeman, you are right about fermat's principle for refraction and there is laws of reflection which using fermats principle as methodology.
Check it out here:
http://http://hyperphysics.phy-astr.gsu.edu/HBASE/phyopt/Fermat.html"
So the thing is i am not satisfied with the experiments i did with TCS230, i have this thought that i could perform more on this sensor, so as you know its directly got to do with light, what else experiment i can do with this sensor, may be through illumination, surface, or wavelength or whatsoever, so i don't really have any idea right now, so i need ideas from pros like you, please help me. let me tell you in detail about the experiments i done so far.
1st was i used this color sensor without any diffuse illumination and only got the reading which fluorescent lights illumination in my lab, therefore when i read the through the medium which is an A4 paper printed with colors and my sensor on top of it, so there was no proper reflection and only shadow left, so i prove this with laws of reflection correlated to fermats principle.
2nd i did a new board with White Led, white led because through my research i found that white led blocks other ambient light, correct me if I am wrong, then the output was perfect with i measured the same color with diffrent intensity, which from dark to bright, like an example for red, from 0 to 255, and the output keep increasing according to brightness. so i prove the diffuse reflection works fine with lamberts cosine law.
now i need idea to further extend my experiment, i really want to squeeze out everyting i need to know about this, please give me idea, i just need idea with some guidance, I am not really good with physics, sorry about that.
another thing is how actually this internal light to frequency converter works, i really couldn't get proper resource on that, please guide me as well.
Thank you!
The TCS230 does NOT convert the visible light to frequency. It has outputs that put out different frequencies (few kHz to 500 kHz) for various color (red green blue) light illumination. Read the data sheet.
If you want to play with different colors to see if you can reproduce the data-sheets "PHOTODIODE SPECTRAL RESPONSIVITY" you could use filters, vary the intensity, and record the frequency output. http://www.edmundoptics.com/" .
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
