Light from electron levels, but radio from AC?
Light is generated by electrons transitioning to lower energy states, releasing energy as photons, while radio waves are produced by alternating currents creating changing electromagnetic fields. The discussion explores the feasibility of generating light through high-frequency alternating currents, specifically at 600THz, and whether non-sinusoidal waveforms like sawtooth or square light can be achieved. Concerns are raised about the limitations of electron interactions at such high frequencies and the size constraints of conductors. Additionally, it is noted that atomic transitions can produce radio frequencies, such as the 1420 MHz line from hydrogen, which is relevant in astrophysics and SETI research. The conversation concludes with questions about the potential maximum frequency for light generated from alternating currents.
mrneglect
I know that light (such as that emitted by a fluorescent bulb) is generated by electrons falling into lower energy states and releasing an amount of energy as a photon. But radio is transmitted by producing an alternating current in a conductor, and (I assume) it's the acceleration and deceleration of this electric charge which creates the changing electromagnetic field which propagates away from the source.
Can light be produced in the same way? Is it feasible to produce an alternating current in the order of 600THz? If so, could we produce things like sawtooth, triangle and square light rather than the usual sinusoidal?
I have a feeling there's some 'springyness' to electron interaction and it would be difficult to produce a frequency of 600THz in any conductor larger than about 500nm, but I'd like to hear some thoughts on it.
Similarly, do any atoms contain such close-together energy levels that an electron might produce something in the order of kHz or MHz when it falls to a lower energy level, or do all radio waves have to come from some kind of alternating current?
The atomic hydrogen line known as the 21 cm line or the 1420 MHz line is observed in intersteller hydrogen gas. It is hyperfine structure of electrons in the 1s state, and can be both emitted and absorbed by the hydrogen gas. The 1420 MHz line is one of the most popular lines used in the SETI (Search for Extraterrestrial Intelligence) search. This frequency can be generated by both atomic transitions (masers) and by microwave oscillators. It is roughly 60% the frequency in microwave ovens. See
http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/h21.html
Aha, OK, so you can get some pretty low energy photons coming out of atoms, but what about high energy photons out of alternating current? Is there some maximum cut-off there too?
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
