Calculating Limiting Reagent and Percent Yield for Gasoline Combustion
  • Thread starter Thread starter hima
To solve the problem involving the combustion of gasoline (C8H18), first determine the limiting reagent by converting the mass of gasoline (2.62 kg) into moles using its density, which is necessary since the volume is given in gallons. The reaction shows that 2 moles of gasoline react with 25 moles of oxygen. Calculate the moles of oxygen available from 7000.0 L at STP, where 1 mole of gas occupies 22.4 L. Next, identify which reactant is limiting by comparing the mole ratios. After determining the limiting reagent, calculate the mass of carbon dioxide produced using stoichiometry based on the balanced equation. Finally, to find the percent yield, compare the actual mass of carbon dioxide collected (6.4 kg) to the theoretical mass calculated from the stoichiometric results. The percent yield is calculated by dividing the actual yield by the theoretical yield and multiplying by 100.
hima
please i need to solve this problem, can you help me out. thank you.
equation: 2C8H18 (l) + 25O2 (g) → 16CO2 (g) + 18H2O (l)
a)2.62kg(one gallon) of gasoline is burned with 7000.0L of oxygen gas at STP. what is the limiting reagent?
b) what mass of carbon dioxide is produced in part?
c) if 6.4 kg of carbon dioxide is collected in the lab using the amounts in part(a), what is the percent yield for this experiment?
Chemistry news on Phys.org
Could you please tell us what you have done already, and where exactly you need help/don't understand?
The questions are clear, but the problem is that we can't answer to homeworks here .
You would perform most of your calculations in mole units. Since your given quantity of gasoline is in gallons(a volume unit), you need to know this gasoline's density (or specific gravity, at least something to work with); the density will give you the mass, and the mass will give you the moles (obviously using suitable conversion calculations).
The "l" in your reaction means "liquid", and the "g" in your reaction means "gas"
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
