Can a Square Coil Fit into a Round Solenoid?
  • Thread starter Thread starter nb121307
    Coil Hole Square
A square coil with a side length of 1.75 cm is placed inside a solenoid with a radius of 2.82 cm and a length of 22.0 cm, wound with 113 turns of wire carrying a current of 3.29 A. The magnetic field strength was calculated using the formula B = μ0 N I, resulting in B = 4.67 x 10^-4 T. The flux through the coil was calculated using Φ = BA, but the result of 1.43 x 10^-7 Wb was deemed incorrect. The discussion emphasizes the importance of correctly applying the magnetic field formula and suggests verifying calculations against reliable sources. Accurate calculations are crucial for determining the magnetic flux in this scenario.
nb121307
A square, single-turn wire coil L = 1.75 cm on a side is placed inside a solenoid that has a circular cross section of radius r = 2.82 cm.
http://capa8.phy.ohiou.edu/res/ohiou/serwaylib/Graphics/Graph20/serw2014.gif
The solenoid is 22.0 cm long and wound with 113 turns of wire. If the current in the solenoid is 3.29 A, find the flux through the coil.
Є=(ΔNΔΦ/Δt)
ΔΦ=BAcosΘ
B=μ0NI
I have found the strength of the magnetic field using the constant μ0 = 12.57x10^-7, the number of turns 113, and the current 3.29 A, and because time is not applied Δt can be taken out of the equation to get Є=ΔNΔΦ=ΔN(BAcosΘ). This gives me B = 4.6731489x10^-4 or B = 4.67x10^-4 The next part of the question asks for the flux and the strength of the magnetic field is required to do so. However, when applying the strength of the magnetic field and the area of the square coil using the equation Φ = BA the answer I am given is Φ = 1.43x10^-7 Wb which is apparently wrong. I'm not sure what I am doing wrong and any help with this would be greatly appreciated.
Welcome to Physics Forums!
Є=(ΔNΔΦ/Δt)
That equation isn't relevant, since they are not asking for Є.
ΔΦ=BAcosΘ
Okay. But strictly speaking, this would be Φ and not ΔΦ. Nothing is changing in this situtation.
B=μ0 N I
If N means the number of turns, then this expression is missing something. Check this out:
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/solenoid.html#c2
Try calculating B using the link I give above, then you can use the flux equation you had to find the flux.
