How Do We Distinguish Poles in Liquid State Magnets?
Distinguishing poles in liquid state magnets is complex, as traditional concepts of magnetism apply differently to flowing materials. Liquid magnets, such as ferrofluids, respond to magnetic fields but do not exhibit ferromagnetism like solid iron. Heating iron causes it to lose magnetism before melting, complicating the understanding of magnetic properties in liquid states. In magnetic resonance imaging (MRI), the dipole orientation of substances like aqueous hydrogen can be detected, but this does not equate to traditional magnetic poles. Overall, discussions on magnetism should clarify whether they refer to ferromagnetism or other magnetic behaviors to avoid confusion.
monty37
how do we distinguish poles in case of a liquid state magnet ..or do they tend
to lose their magnetic property?
Magnetism is a property not of iron atoms, but of bulk iron. When you heat iron, it loses its magnetism long before it melts.
There are some materials: ferrofluids for example, that respond to magnetic fields. As an extreme example, MRI is used to detect the dipole orientation of (aqueous) hydrogen. I'm not sure if you are thinking of either.
There's not much sense to speak of 'poles' in those cases, since the material can flow.
Ferrofluids do not display ferromagnetism, nor does water in NMR. While "magnetism" is a huge field with many different behaviors, I think it's safest to assume posters are talking about ferromagnetism unless they specify otherwise.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
