Gravity Above 8000km: How Distance Affects Attraction
Gravity decreases with distance from the Earth's center, following an inverse square law, meaning that at double the distance, gravitational pull is reduced to a quarter. Despite this decrease, gravitational attraction never completely disappears; it only weakens and can be countered by other gravitational influences from celestial bodies. In space, while gravity from Earth diminishes, other sources like the Moon or Sun can exert their own gravitational forces. Astronauts experience weightlessness in a space shuttle because they are in free fall, creating a sensation similar to descending in an elevator. Ultimately, Earth's gravitational field is effectively infinite, though its strength diminishes with distance.
no idea
is the gravity above the ground 8000km is less gravity from the ground than on the ground?because i think that the distance will affect the attraction
Yes, the attraction of gravity decreases as one gets further from the central sourxce of gravitational influence. It is a function of the sqaure of the distance, meaning that if you get twice as far away, gravity is 1/4 as strong, three times the distance and gravity's pull is 1/9, etc.
but why the thing still drop
No matter how far you go from the source (in this case, the center of the earth) there will still be a gravitational attraction, only it will be weaker. If you go into space though, there are other planets/stars that start attracting you towards them.
Gravity gets weaker with distance, but it doesn't go away until it is neutralized by something else in the opposite direction. For example, going from Earth to moon there is a point where the effects cancel.
Actually, it never goes away, it just becomes infinitely small. If you were to hurl a ball upwards at sufficient speed, it would keep slowing down forever, although the rate of deceleration will decrease. Of course, the gravitational fields of other bodies (in your example the moon) would influence the ball's flight path as well, so if you launch it at the sun, the ball would be pulled into it. But on a stricly theoretical level, the Earth's grav field is pretty much infinitely large.
The fact that astronauts are "weightless" in a space shuttle is due to the fact that they are in a constant free fall around the earth. There still is gravity, but they don't feel it. It's an effect fairly similar to that what you feel in an elevator when it starts to descend.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
