Laplace Equation on semi-infinite plate
A problem involving a thin semi-infinite conductive plate with a voltage applied at one end was discussed, where the goal was to find the voltage V(x) at a distance x from the end. The initial solution, V(x)=-90*x+1, did not satisfy the boundary conditions at infinity, while the correct solution, V(x)=V0*10^(-x/d), did. The discussion highlighted that electrostatic potential satisfies Laplace's equation in regions with zero charge density and Poisson's equation otherwise. The realization that the problem involves a conductor clarified why the correct solution does not satisfy Laplace's equation. The charge density as a function of x was also mentioned as epsilon_0*(ln10)^2*exp(-x/d).
ZombieCat
Hello all!
I just finished the following problem:
Consider a thin semi-infinite plate of negligible thickness made of an isotropic conductive material. A voltage V0=1V is applied at x=0 on the plate (across the short dimension). At a distance x=d=1cm from the end (x=0) V is measured to be .1V. Find the voltage V(x) at an arbitrary distance x from the end.
In my first attempt I got V(x)=-90*x+1, which is a solution to the Laplace equation in 1D, but does not match the boundary condition at infinity.
I tried the problem again and got V(x)=V0*10^(-x/d), which matches all boundary conditions and is the correct answer. My question is why doesn't this solution satisfy the Laplace equation? Does it have to? Why/why not?
The electrostatic potential only satisfies Laplace's equation in regions where the charge density is zero. The rest of the time it satisfies Poisson's equation.
Oh dangit! Cause we're dealing with a conductor gotcha! So I guess the epsilon_0*(ln10)^2*exp(-x/d) would be the charge density as a function of x.
Thanks!
*Maybe I should rename myself "the phorgetful physicist"...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
