Understanding Bragg's Law in X-Ray Diffraction
manofphysics
We all know, Bragg's law , n\lambda=2dsin\theta
where 2dsin\theta=path difference.
In the derivation of the path difference we take the two incident rays to be parallel which is perfect BUT we take reflected rays also to be parallel.How can this be since the reflected rays have to MEET for superposition to take place.
This is the same as in FRAUNHOFER diffraction, where we CAN take parallel rays due to the distance being effectively infinity or due to the use of LENS.
But we are not using a lens nor is the distance supposed to be very large(infinity) in the experimental methods of Xray diffraction ( rotating crystal, powder photograph etc.).
So, how is it that this formula works?
I'm missing something here.
You have parallel incident waves reflecting from parallel planes...why wouldn't the reflected rays also be parallel?
Or are you trying to treat the wavefront as a single point rather than a plane?
when an EM wave strikes an atom, a spherical wave front is emitted. ie waves are emitted in ALL directions . Now we are considering the emitted rays by two atoms which are parallel,
But the parallel rays will not meet for interference, we need to use a lens...
(I am using an analogy of diffraction in optics here. as both are almost similar, I think)
The rays do meet because the rays are not exactly parallel. They are only approximately parallel. And the approxmation is good enough because the place where they meet is "far" away.
So, I guess it is the same assumption that we take in Fraunhofer diffraction.
Thanks for the reply ,Edgardo.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
