Cheetah Acceleration: Solving Homework Problem in 3.2s
A cheetah must match the distance covered by its prey, which runs at a constant velocity of +10.0 m/s for 3.2 seconds. The total distance the prey covers is 32 meters. To determine the cheetah's required constant acceleration from rest, the kinematic equation can be applied. The solution involves calculating the acceleration needed to cover the same distance in the same time frame. Proper problem-solving procedures, including showing work and relevant equations, are essential for clarity and understanding.
12345ME
A cheetah is hunting. Its prey runs for 3.2 s at a constant velocity of +10.0 m/s. Starting from rest, what constant acceleration must the cheetah maintain in order to run the same distance as its prey runs in the same time?
Hi 12345ME, welcome to PF. Please read the rules and follow them. To get help, follow the homework template, show the relevant equations and explain what you have done as an attempt to solve the problem.
