Exponential functions, and complex numbers
The discussion focuses on solving the equation e^(iz) = i - 1 by rearranging for z. Participants suggest using the logarithm of both sides, leading to the expression z = ln(i - 1)/i. The conversation also explores the relationship between the exponential function and trigonometric functions, specifically how e^(iz) can be expressed as cos(z) + isin(z). Further insights include using trigonometry to analyze the intersection of the line segment between i - 1 and the unit circle. Ultimately, the solution is confirmed to be z = ln(i - 1)/i, acknowledging that this represents the principal value with additional complex solutions possible.
string_656
hey I am doing some questions outta a txt book, i sort of understand complex numbers, like multiplying and dividing, ..
The question asks to rearrange for z,
e^(iz) = i - 1
im not sure what to do with the exponential function.
thanks for the help
Mathematics news on Phys.org
Are you familiar with the log function for complex variables?
hmmm no... that sounds like that could help
.. does any 1 no how i could solve this?
You want to take the log of both sides of the equation. Look in your textbook for more information.
Note: some books use ln instead of log.
HTH
Petek
hmm ok so that gives...
z = ln(i - 1)/i
it can't be that easy?
what about... since e^(iz) = cos(z) + isin(z)
cos(z) + isin(z) = i - 1
Then how would i solve for Z?
Think about where the line segment between i - 1 and 1 intersects the unit circle. Use trigonometry since exp(z)=exp(x+y*i)=exp(x)*[cos(y)+i*sin(y)]
z = ln(i - 1)/i
z = ln(i - 1)/i
is right, it depends on the form you want the answer in
solving this will work but z will be complex
write i-1=sqrt(2)(i*sqrt(2)/2-sqrt(2)/2)
then solve
exp(x)=sqrt(2)
and
cos(y) + isin(y)=(i*sqrt(2)/2-sqrt(2)/2)
y real so
cos(y)=-sqrt(2)/2
sin(y)=sqrt(2)/2
tan(y)=-1
hmm ok .. just a question, when its iz = ln|i-1|
wouldnt i go z = ln(i-1) * (0+i)
(0 - i) * (0+i)
because I am just remembering when you divide complex numbers that's all.
opps that didnt post right
wouldnt i go z = ln(i-1)/(0 - i) *(0+i)/(0+i)
exp(iz)=i-1
take log
log(exp(iz))=log(i-1)
log cancels exp
iz=log(i-1)
divide by i
z=log(i-1)/i
that is the principle value , there are others
oh, ok thanks.
