Finding the distance between a point and a level curve
To find the point on the curve defined by 5/8 x^2 - 3/4 xy + 5/8 y^2 = 1 that is closest to (1, -1), the gradient vector was calculated as <(5/4x - 3/4 y), (5/4y - 3/4x)>. The discussion highlights the need for a second equation to relate the two variables, as there is one equation with two unknowns. It was noted that the problem can be approached by optimizing a function under a constraint, suggesting the use of Lagrange multipliers. This method allows for finding the minimum distance from the curve to the specified point effectively.
yeahhyeahyeah
Find the point on the curve defined by 5/8 x^2 - 3/4 xy + 5/8 y^2 = 1
That is closest to the point (1,-1)
I started by finding the gradient vector. < (5/4x - 3/4 y) , (5/4y - 3/4x) >
I could not figure out if that was even the right direction to go in because I don't know how I'd even find a distance formula
You have one equation with two unknowns, so you need another equation relating those two variables. You do have information to construct another equation: the distance from the curve to the specified point is a minimum. Write down an equation that expresses that condition, and then solve the two equations for the two unknowns.
ah nvm i realized its just optimizing a function with another contraining function.. i think... so i could use lagrange multipliers
thanks for your help
