Find the tension in the rope and forces exerted by the floor
The discussion focuses on calculating the tension in a rope and the forces exerted by the floor on a step ladder with a suspended weight. The user initially derived equations for equilibrium but struggled to find the correct tension value, which should be 96.7 N according to the textbook. A mistake was identified in the angle calculation, affecting the results. Additionally, it was noted that the values of the reaction forces R and S are independent of the ladder and rope lengths. The user inquired about a potentially shorter method to solve the problem.
deathnote93
I'm new here, so please bear with me.
http://img15.imageshack.us/img15/9325/questionq.png​
[/URL]
Verbatim from my textbook:
As shown in Fig.7.40, the two sides of a step ladder BA and CA are 1.6 m long and
hinged at A. A rope DE, 0.5 m is tied half way up. A weight 40 kg is suspended from
a point F, 1.2 m from B along the ladder BA. Assuming the floor to be frictionless
and neglecting the weight of the ladder, find the tension in the rope and forces
exerted by the floor on the ladder. (Take g = 9.8 m/s2)
Condition for equilibrium: Net force=0 and net Torque(\tau)=0
\tau=rF sin\theta
http://img36.imageshack.us/img36/5815/questiono.png​
[/URL]
Let the angle BAC be 2x, tension in string be T, hung weight of 40kg be W, and the reaction forces of the floor be R and S.
Then, for the equilibrium of AB(net torque=0):
0.4W*sinx + 0.8T*cosx = 4Rsinx which on simplification led to
T = 2/3 *tanx(4R-W) ------(1)
For the equilibrium of AC (Net torque=0)
0.6*T*cosx = 1.6*S*sinx
T = 8S/3 tanx --------(2)
For vertical equilibrium of ladders, W = R + S -------(3)
Equating 1 and 2,
R - S = W/4 --------(4)
Solving 3 and 4, I got R=245 and S=147 which are correct answers.
The next question is to find the tension, which is what I'm having trouble with. Using either the law of sines or the law of cosines gives me x=24.6 degrees, and substituting that into eqns 1 or two gives me the wrong answer for the tension - the correct answer according to the book is T=96.7N.
Any help is appreciated.
AE and BD are 0.8 long, not 0.6, so your value for x is wrong.
The values of R and S are independent both the length of the ladder and the length of
the rope BTW. This is easy to see by considering the torque around F on the entire ladder
That sucks, I don't usually do stupid things like that. Thank you very much.
Also - is there a shorter way to do this problem?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
