Why is Silver Not Widely Used in Electrical Wires?
  • Thread starter Thread starter Missionz12
    Wires
Silver is an excellent conductor of electricity, outperforming copper by only 8%, which makes copper a more cost-effective choice for electrical wiring. The significant price difference, with silver costing around $526 per kilogram compared to copper's $5.84, further discourages its widespread use. While gold is utilized in high-end applications due to its corrosion resistance, copper remains the primary material for most wiring needs. Silver is occasionally used in specialized applications, such as RF work, where its properties enhance performance. Overall, copper's balance of conductivity and affordability makes it the preferred choice for electrical wires.
Missionz12
I've read that silver is the best conductor of electricity so I am curious why we do not use it in wires like we use gold,copper,etc...
Silver is a good conductor but not all that much better than Copper which is a lot cheaper.
As you can see from the following table of resistivities, Silver is only 8% better than Copper as a conductor
Silver 1.59×10−8
Copper 1.72×10−8
Gold 2.44×10−8
Aluminium 2.82×10−8
Today,
a Kilogram of Silver is worth US$526
a Kilogram of Copper is worth US$5.84.
Gold is worth US$996 per OUNCE or US$32021 a Kilogram
Hello Mission Z-
During WW II, one or more Calutron magnets (very big dipole magnets) at Oak Ridge used for separating U235 from U238 (isotope separation) had silver coils. This apparently was because copper for shell casings (ordnance) was in short supply, and Fort Knox had a very large stash of silver bars. I also understand that coils in military transmitters had solid, rather than silver-plated, coils. I think all of these silver coils have been melted down. The U.S stopped making silver coins about 1966.
Bob S
For the most part we use copper because it has good conductivity, and also because it's relatively cheap. Gold is used in high end applications, but as you can imagine it's expensive.
The only other metal I know of that gets used commonly is aluminum for the main lines in houses and such.
Copper is still a better conductor than gold. Gold is mainly used in connectors due to its resistance to corrosion.
(unless with high end you mean hifi, where there are claims gold cables "sound" better :rolleyes:) (of course not backed up by any science at all, but that's not surprising considering they also use cable stands to give the sound some "air" :smile:)
I still see silver plating used in RF work. Due to the shallow skin depth at higher frequencies, it's practical to plate waveguides, resonators, and coils for matching networks. Thus Q values are increased and losses are reduced.
I've also seen copper plated aluminum used for the center conductor of CATV lines. I assume this is because copper is more expensive than aluminum, but again, only a thin layer is needed.
- Mike
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
