How does a frequency multiplier work?
  • Thread starter Thread starter rjsalmon
    Frequency Work
Frequency multipliers work by using non-linear devices, such as diodes, to generate harmonics of an input signal, effectively multiplying its frequency. This process involves driving an amplifier into distortion to create a complex waveform, from which specific harmonics can be extracted using tuned circuits. Alternatively, a free-running oscillator can be employed, where its frequency is divided and compared to a reference signal to achieve precise frequency multiplication. The discussion also highlights the use of frequency multipliers in generating terahertz signals, noting the high costs associated with such setups. Additionally, it mentions the generation of green laser light from an infrared laser through a non-linear crystal, demonstrating practical applications of frequency multiplication.
rjsalmon
Hi,
I'm trying to work out how frequency multipliers physically work. What processes go on in order to multiply an input signal to a desired amount (ie 2 or 3 times the original frequency). I am interested in their use to generate a terahertz signal though I assume they work the same at most frequencies.
I hope someone can help.
Likes Ali Devrim OGUZ
I can think of two types of frequency multiplier.
The first uses an amplifier that is deliberately driven into distortion so that a complex waveform is produced.
This will contain output on multiples of the input frequency.
Tuned circuits are then tuned to the required harmonic to recover this harmonic and reject others.
This is typically done in receivers and transmitters where a known stable signal is available but a multiple of that frequency is needed as a local oscillator for a mixer.
The other type of frequency multiplier is one that uses a free running oscillator near the desired high frequency. This oscillator frequency is divided by some exact amount using a digital divider.
This divided down signal is then compared with a known reference in a phase comparator and an error signal is sent back to the oscillator to pull it onto an exact multiple of the reference signal.
I also saw a reference to someone multiplying the frequency of a red laser to get green laser output. I have no idea how they did that.
Multiplication occurs when a sine wave is subjected to a non-linear device such a as diode that has an exponential response
i \sim e^vIf you know calculus, you can expand the exponential using Taylor series:i \sim 1 + \frac{v^2}{2} + \frac{v^3}{6} ...+ \frac{v^n}{n!}Notice, we have the v^2 term - if you square a sine wave
v = \sin(\omega t)
\sin^2(\omega t) = \frac{1}{2}(1-cos(2\omega t))and hence the frequency is doubled. Note, that the higher order terms are usually negligible. It is possible to optimize the diode for the 3rd order term to triple the frequency or quadruple it. But the power goes down quickly.
The t-rays are primarily generated by multiplication, however, the expense and quality of components that goes in making these is huge. A simple set up could cost you as much as a new car.
Instead, consider working at lower frequencies in the KHz, and MHz range which is cheap to do.
Also as vk6kro, mentioned, the light in green laser pointers is actually derived from an infrared laser shining into a non-linear crystal that generates the 2nd harmonic (green light), you can experiment with that:
Here is an example of a laser doubler:
Brilliant, thank you both very much. Its too difficult to find this information out online.
Rob
Thank you for sharing your information
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
