Angle turned relative to earth?
To determine the angle turned relative to the Earth when flying from Kampala to Singapore, the Earth's circumference, approximately 25,000 miles, is essential for calculations. The distance of 5,000 miles represents about 20% of the Earth's circumference. Since a full circle is 360 degrees, this translates to an angle of about 72 degrees (20% of 360). The discussion emphasizes the need to understand the relationship between distance traveled and the total circumference to find the angle. This approach clarifies how to calculate the angle of turn in relation to the Earth's surface.
thedarkone80
The Earth's radius is about 4000 miles. Kampala, the capital of Uganda, and Singapore are both nearly on the equator. The distance between them is 5000 miles. Through what angle do you turn, relative to the earth, if you fly from Kampala to Singapore? Give your answer in degrees.
No clue
Have tried using triangles, haven't gotten anywhere. Please help.
What's Earth's circumference? How many percent of that is 5000 miles? Since there are 360 degrees in a circle, how many does 5000 miles correspond to?
maybe the radius and the distance between the countries form a right angle. with this find the angle made by the radius and the hypotenuse. Divide 360 by this number, than multiple 5000 to your answer.
The percentage of the Earth's circumference is about 20%. But i don't understand what you have mentioned about how 5000 miles corresponds to the 360 in a circle?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
