Solving LED Power Supply Issues: Tips from John
  • Thread starter Thread starter John Readman
    Led
Calculating the power supply for a series of LEDs involves determining the total forward voltage and current requirements. It's essential to consider the forward voltage drop for each LED, typically around 2V for red LEDs, and multiply this by the number of LEDs in series. A current limiting resistor is necessary to prevent excess current, calculated using the remaining voltage after accounting for the LEDs' total forward voltage. Users are advised to double the calculated current draw for the power supply rating to ensure safety and reliability. Utilizing online LED calculators can simplify this process and help avoid common mistakes.
John Readman
Hi,
I am trying to link up a series of LEDs and having a bit of trouble calculating the power supply needed. I am actually doing this for a number of applications and wondered if anyone had a system for working this out??
Thanks,
John
LED's in paralell? 12Volts always worked good for me. Dont forget the current limiting resistor of appropriate wattage. Usually 1500+/- Ohms worked good for current limiting on 12VDC.
To be safe, figure the current draw of the LED's and then double it for the power supply rating.
P.S I have seen people use LED's on 110VAC, they will "self rectify", you just still need the appropriate current limiting resistor, and PLEASE consider safety around 110.
Is this for an experiment?
Perhaps some formulas will pop up, these are the "rules of thumb" I have used for decades.
Thanks for your post. Let me offer an example I am linking 10 No LEDs in series (I think, they are one after the other)
Reverse Current VR = 5V
Power dissipation 120 mW
DC Forward Current 30 mA
Peak Forward Current [1] 100 mA
Reverse Voltage 5 V
Which of these pieces of info would I use to calculate the required power??
Maybe cheating, but try one of the many LED calculators available online. http://led.linear1.org/1led.wiz" .
Reverse Voltage 5 V
Your first line of "reverse current" looks to be a typo. There is generally no reverse current spec for LEDs, just a maximum reverse voltage before they pop.
Also, you generally do not put LEDs in series unless they are well matched. Otherwise the difference in brightness can be seen. If they are well matched, then you should be able to series-connect them.
What is the typical forward voltage specified for when you are running them at 30mA? Probably around 2V if they are red LEDs, and a bit higher for other colors. You will choose your power supply voltage and series current limiting resistor to match up with the forward voltage drops and target forward current.
For example, 10 red LEDs would require a total of about 20V at 30mA (series connection). So if you had a 24V power supply, you would have 4V left over to drop across the current-setting resistor. 4V/30mA = 133 Ohms, which just happens to be a standard 1% resistor value.
First, find out the operating voltage of the led's. Surely this must be given as part of the manufacturer's data. Let's say it's 1.6 volts.
Now multiply the 1.6 by however many leds you want. If it's 10 leds, they'll take 16 volts to get 'em running.
Now, say you've got a 30 volt supply. Then 14V/30mA=V/I=R. If you put that value of R is series with the leds they'll get their 30 mA.
Let me mention what happens if you have only 17 volts to play with. In that case the system becomes very sensitive to the exact value of R, and also to the exact characteristics of the led's.
As for power, use current x voltage.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
