How Does Throttling Affect Enthalpy and Velocity in a Converging Nozzle?
Throttling in a converging nozzle typically assumes constant enthalpy, leading to the conclusion that h1 equals h2. The enthalpy drop can be calculated using the formula h1 - h2 = (v2^2/2) - (v1^2/2), indicating that kinetic energy changes during the process. However, in a throttling scenario, the kinetic and potential energies are often neglected, reinforcing the idea of constant enthalpy. The first law of thermodynamics supports that total energy before and after expansion remains equal, assuming no heat or work interactions. Thus, while kinetic energy may increase, it is generally considered negligible in the context of throttling.
leon25034796
Can someone explain something to me:
I believe when throttling h1=h2.
When calculating enthalpy drop across a FIXED converging nozzle then kinetic energy is caluclated using the following formula:
h1-h2 = v2^2/2 - v1^2/2
If the nozzle is converging then there will be an increase in kinetic energy, but, if assuming the nozzle is throttling with a respective pressure drop then how can h1=h2 as this would mean v1=v2?
Thanks
Thanks
The typical assumption for a throttling device is that the kinetic and potential energies are neglected. Hence the enthalpy is constant.
CS
Hi leon
Note that this equation can be rewritten:
h1 + v1^2/2 = h2 + v2^2/2
This is the first law of thermo with the velocity added into account for kinetic energy. It says that the total energy prior to expansion is equal to the total energy after expansion. This obviously assumes no heat or work was done on or by the fluid.
As stewart mentions, kinetic energy is normally very small and can be neglected.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
