Abundancy of Uranium 235 when the earth was formed.
  • Thread starter Thread starter SuperPokenerd
    Earth Uranium
SuperPokenerd
The Earth is about 4.5 billion years old. If 235U is 0.65% abundant today, how abundant was it when the Earth formed? Note, in this case abundancy is defined as the ratio of Uranium 235 to Uranium 238
R=N(lambda)
N=N0e^-lambda(t)
Half Life = ln(2)/lambda
I am really unsure how to do this problem. I tried reworking the above equations but I was not able to get the correct answer. I need a little help getting started.
In your second equation, you can divied by N0 to give N/N0. What would this quantity represent? Think about the total range of values this quantity could take on. Can N be negative? Can N>No?
Well, N/N0 would be the probability that a nucleus has decayed in the given period of time which in this case would be -4.5billion years if we take t=0 to be the present. And can't N be larger than N0 if we are going back in time?
ok, so I've worked it up to the point where I have the new abundancy = .0065e^(lambda238-lambda235)*4.5billion years but it's wrong. How can i fix this?
Got it wrong so now I got an 80 on my HW. Thanks for nothing.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
