U-shaped tube- how far does the mercury rise when water is poured into one side?
When water is poured into one side of a U-shaped tube containing mercury, the pressure exerted by the water column must equal the pressure difference in the mercury columns. The water column is 15.0 cm deep, which creates a specific pressure that affects the mercury levels. To find how far the mercury rises in the right arm, the pressure from the water must be calculated and matched with the mercury's pressure difference. This involves using the equations for pressure, factoring in the densities of water and mercury. Ultimately, the solution requires equating the pressures to determine the mercury's rise in the right arm.
kalisious
U-shaped tube-- how far does the mercury rise when water is poured into one side?
A U-shaped tube containing mercury is open to the air on both ends. Water is poured into one arm until the water column is 15.0 cm deep. How far upward from the initial position does the mercury in the right arm rise?
P = P0+density(gh)
P = P0+(density*h)(g)
I am not sure how to go about this solution!
The pressure from the water column must match the pressure from the difference in the mercury columns. Once you know this difference it's easy to find how much the mercury in the right arm has risen.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
