Comparing Quasar Varying Timescales to Black Hole S Radius
CaptainEvil
If a quasar varies on a time scale of four months, how does the maximum size of the emitting region compare with the Schwarzschild radius for a 109 MSun black hole?
Calculating the S radius of the black hole is trivial, but I think I missed the lecture on varying quasars. I don't know of any equations for 'emitting regions' let alone how to use its rotation period to do so. Can anyone start me off on the right track?
fwiw I calculated the S radius by the eqn 3km(M/Msun) = 3 x1012 m
if the source varies on a time scale of 4months what's the maximum size it can have?
hint - you are probably supposed to picture it's extent in a line of sight to you and assume the actual brightness change is instantaneous an comes from the full extent of the source.
I see, so are we assuming that it can only extend to a maximum size of 4 light months?
4 light months corresponds to roughly 3.1 e15 meters, which is about 1000 times the size of the S radius of the black hole.
Does this sound right?
That's how I read it.
In reality the emission is going to come from a large acreation disk around the hole so it's easy to imagine that as 1000x the Rs
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
