Energy and simple harmonic motion
The discussion revolves around calculating how far a bungee jumper is from the water at the lowest point of their fall, given specific parameters such as weight, bungee cord length, and spring constant. Participants suggest breaking the jump into two stages: free fall and the subsequent elastic stretch of the bungee cord. The first stage involves free falling a distance equal to the unstrained length of the cord, while the second stage applies Newton's laws to account for the forces acting on the jumper. Key equations discussed include the conservation of energy and the relationship between elastic force and acceleration. The conversation emphasizes the need for a systematic approach to solving the problem using these principles.
jacksonpeeble
A 74.4-kg bungee jumper is standing on a tall platform (h0 = 46.6 m). The bungee cord has an unstrained length of L0 = 9.54 m and, when stretched, behaves like an ideal spring with a spring constant of k = 61.8 N/m. The jumper falls from rest, and it is assumed that the only forces acting on him are his weight and, for the latter part of the descent, the elastic force of the bungee cord. Determine how far the bungee jumper is from the water when he reaches the lowest point in his fall.
mghf+.5ky2=mgh0
No idea, made several attempts with results close to 10.
Try finding how much the cord extends when the person jumps.
How far is the jumper from his initial position when he is at the end of the maximally stretched cord?
ehild
in my opinion you can divide the jump into 2 stages: 1) free falling (H of free falling = L= 9.54) 2) movement on y asis and in this stage you can set equation (using Newton's laws) weight force (m*g) - elastic force = m*a
Thank you everyone for your advice - I am curious - in what order should I go about doing these operations.
For instance (without necessarily plugging in numbers for me, which I know would defeat the purpose of me actually learning the material), is there a step-by-step procedure that should be followed (and other equations)?
in the first stage you can solve nothing but in second one you should use formula F(elastic) = k*(L-L0) and inferring from Newton's second law, that is any force = m*a we can get equation k*(L-L0) = m*a the acceleration is g=10m/s^2 because it is a vertical falling (i am not sure about my opinion but i think that..)
transforming the equation we can get that L = (m*g+k*L0)*k and a length between the water and the reachest point is H0-L
