Raising momentum operator acting on spherical harmonics
FourierX
What is the result of raising momentum ladder operator (L+) acting on spherical harmonics Y04 (\theta,\phi)
I was expecting Y14 (\theta,\phi)
I applied L+ on Y04 (\theta,\phi) and ended up with Y14 (\theta,\phi) multiplied by \sqrt{20}h-bar.
Thanks in advance
That is what you should get:
<br /> L_+Y_\ell^m=\hbar\sqrt{(\ell-m)(\ell+m+1)}Y_\ell^{m+1}<br />
with \ell=4 and m=1, you get
<br /> L_+Y_4^0(\theta,\phi)=\hbar\sqrt{20}Y_4^1(\theta,\phi)<br />
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
