Find the slope of the tangent line using a specific formula
Centurion1
g(x)=3t-t2
at (0,0)
Im told to use this equation by the book
f(c+deltax) - f(c)
Deltax
Everytime i plug it in by way of the books style i get 2c. and then you are supposed to plug in the x value which gives me 0. But the right answer is 3
Perhaps if you show some of your algebra...
sorry.
yeah I am not so sure its an aritmetic mistake but a misunderatanding of how to do things. but following what the book said to do here goes,
f(c + deltax) - f(c)
delta x
((c + deltax)2 - 3t) - (c2 -3t) foil it out
delta x
2c(deltax) + (deltax)2 simplify
Delta x
and then my book gets rid of both of the delta x's
i assume by simplyfying and i can only assume the deltax2 by plugging in zero because the lim approaches 0
and i get the wrong answer because i end up with 2c (which the book says to do) and then plug in a point which is 0 and its supposed to end up being 3?
You're getting the wrong answer because f(c + \Delta x) \neq ( c + \Delta x )^2 - 3t. You should think about why.
thats the problem the book gives an example for linear problems, eg y= x and parabolas, y=x^2
im not sure what to do with this?
This isn't anything that would be an example in a calculus book, because it's function evaluation. (Although it may be in one of the "introductory" sections.)
If you have a function f(t) what does f(c + \Delta x) mean? It means everywhere in the definition of f that you see a t, you should put a c + \Delta x.
really? its in chapter two of my calculus book section 2.1 finding the slope for a tangent line.
so your saying it should look like
3(c + Delta x) - (c + Delta x)2
so
3c + 3Delta x - c2 + 2c(deltax) + (deltax)2
I know this problem is a calculus problem, I'm saying the issue you're having isn't a calculus issue, so it might not be addressed in the examples.
Yes. You need to put c + \Delta x everywhere you see t. Now do some algebra to simplify...
oh okay i understand what your saying about what I am doing wrong. i realize that f(x) is meant to plugged in whenever you see x. but the formulas was throwing me off.
but is this over delta x like the equation?
Yes, the definition of derivative stays the same.
so you can cancel a single delta x right? what happens with the other delta x's i assume the best one to cancel is the 2c delta x
sorry i know I am making this harder than it should be...
