Taking the AP b and recently i did this lab on collision
  • Thread starter Thread starter victorlee2
    Ap Collision Lab
The discussion revolves around the analysis of collisions in a physics lab, specifically focusing on three types: one stationary car being hit, two cars colliding, and a rear-end collision. The first collision was determined to be elastic as both momentum and kinetic energy were conserved. However, the second collision raised questions due to discrepancies in kinetic energy measurements, leading to confusion about whether it was elastic or inelastic. It was clarified that collisions can be either type based on the conservation of kinetic energy, not merely on the movement of the cars. The importance of experimental results and the potential influence of friction on momentum conservation were emphasized, suggesting a need for further experimentation.
victorlee2
well this is just a over all question. I am currently taking the AP b and recently i did this lab on collision. there were 3 collisions, a) one stationary while another one hits it b) both masses crash into each other c) both has velocity but one has higher velocity to collide with the lower velocity car. So far i did (a) and found that it is elastic collsion since both momentum and kinetic energy is conserved, however when i did (b) the kinetic energies were kinda off, but when i looked it up online, MANY SITES tell me that if 2 cars crash into each other, it is elastic. so idk what i shuld put for this
m1v1^2/2 = m2v2^2/2
^ all up there
I'm not sure what you are saying here. Two cars colliding with each other can be elastic or inelastic. It does not depend upon whether one or both cars are moving but on what happens in the collision. Kinetic energy is conserved if and only if the collision is elastic. That's pretty much the definition of "elastic collision".
No idea where you got those sites from, but NO, that is not true at all. Elastic collisions in reality are really ideal cases. Believe your experimental results; after all your conclusion should follow from the results in a lab right?
wow that was fast lol. ok so for
a) One car is at rest and another car has velocity.
for this part i put collision is elastic because one of my trails came out showing that momentum and kinetic energy is conserved
b) Two cars crash into each other
for this part, i know that momentum has to be the same but my results show me other wise. and from my kinetic energy data results, it shows me that the kinetic energies arent the same, so would this still be an elastic or an inelastic?
and from my observation, the two cars DID recoil after they collided.
c) one car has small velocity while another car with a higher velocity hits it from the rear ( rear end collision )
didnt get up to here yet but i think it would be inelastic collision since both cars will still have velocity after collision?
That momentum is not conserved suggests friction being non-negligible in this particular experiment. However, since your first experiment managed to achieve COLM to a reasonable extent (ie negligible friction), then I would recommend that you repeat this particular experiment.
There is no "I think it would be inelastic". It can be (almost) elastic or inelastic depending on experimental conditions.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
