Boltzman Constant, Emissivity and Surface Area of a filament
The discussion revolves around calculating the surface area of a tungsten filament heated to 2.30 x 10^3 K with an emissivity of 0.31, given that the lamp delivers 35.0 W of power. The relevant equation used is Stefan's Law, which relates power, emissivity, area, and temperature. The calculation shows that the surface area A is derived from the equation 35.0 = 0.31(5.670x10^-8)(2.30*10^3)^4A, leading to A being approximately 7.12 x 10^-5 m². The user confirms the solution is correct and expresses gratitude for the assistance received. The problem has been resolved successfully.
kavamo
A tungsten filament in a lamp is heated to a temperature of 2.30 x 10^3 K by an electric current. The tungsten has an emissivity of 0.31. What is the surface area of the filament if the lamp delivers 35.0 W of power?
Stefan's Law
(a greek letter that looks like P?) P(net)=ekAT^4
35.0=0.31(5.670x10^-8 w/m^2*K^4)(2.30*10^3)^4A
35.0 = 491876.5257A
35.0/491876.5257=A
7.1156069x10^-5
is this correct?
Thanks in advance for your help.
Problem solved! Thank you.
