jostpuur
- 2,112
- 19
I'm troubled by the problem of pumping fuel to a combustion chamber. The big problem is that pressure cannot be directed in some particular direction. So when you see propellant leaving the chamber with a great pressure, it should be kept in mind that the propellant is attempting to leak, with the same pressure, back to the pipes through which the fuel is being injected. I have understood that most of the time the solution to this problem is that the liquid fueled rocket engines simply use extremely powerful pumps. I've found a following joke about this:
http://en.wikipedia.org/wiki/Turbopump
My first question is that where do these pumps get their energy from, like in Saturn V and in Space Shuttle? If you don't think about it much, you might think that perhaps some battery is enough to run the pumps, because it's the combustion chamber from where the real energy to the propulsion comes from, but that wouldn't make sense to me, because the pumps need to fight against the incredible pressure created in the chamber.
Is part of the energy that is generated in the chamber, somehow directed back to the pumps? How could one accomplish that? Or do the pumps have completely own combustion engines, like cylinder engines burning their own fuel?
Another fact which I have found surprising is that the LEM did not use pumps at all. I have the https://www.amazon.com/dp/1844256839/?tag=pfamazon01-20 and it says that
I am left puzzled by this, because according to my intuition the helium injected to the tanks would need to be in equally high pressure as the pressure created in the combustion, meaning that equal thrust might as well be achieved by simply shooting out the pressurized helium.
Earlier I had also considered a question that perhaps burning a fuel in the rocket engines is useless, because one might achieve the same propulsion by simply using the pumps to shoot some passive propellant, like water. I have not understood the thermodynamics of this, but I have been left under impression, that if there are two engines, which both create the same pressure at the mouth of the chamber, but other one shoots lighter particles, and other one heavier particles, then the one with lighter particles would create stronger thrust. Although I don't feel like understanding why that would be the case, I believe that that is the way it is, because otherwise, according to my reasoning, the rockets would work just as well by merely shooting passive propellant with pumps.
But I'm still left unable to come up with an answer to how one could avoid the need of the LEM's helium to be in an unreasonably high pressure when released to the fuel tank.
Turbopumps in rockets are important and problematic enough that launch vehicles using one have been caustically described as a 'turbopump with a rocket attached'- up to 55% of the total cost has been ascribed to this area.
The Bell engineer's approach was to try and eliminate anything which could go wrong with the engine. They started by doing away with the ignition system, instead using hypergolic propellants which would ignite spontaneously when exposed to the vacuum of space. Propellant pumps were discarded by forcing the hypergolic reactants into the engine bell using a pressurised helium system.
By introducing a high-pressure inert gas into the tanks, the two propellants would be forced out evenly and together without the need for unreliable pumps.
