Question about integral and Abs function
njama
Hello!
I want to find
\int_{0}^{2}{|2x-3|}
I know the method for separating the integral on two integrals, but I want to try second method.
I know that
\int_{0}^{2}{|2x-3|}=\frac{|2x-3|(x-3)x}{2x-3}|_{0}^{2}
But in this case I got F(2)-F(0)=-2 and on the first method 5/2.
Why the second method does not work?
Thanks in advance.
What makes you think that the last equation is true?
I don't see where the x(x - 3) comes from, and how taking the derivative of sgn(2x-3) x (x - 3) is |2x - 3| :S
It is.
Let |2x-3|=\sqrt{(2x-3)^2}
\frac{\sqrt{(2x-3)^2}(x-3)x}{2x-3}
Now taking the derivative:
\frac{(\sqrt{(2x-3)^2}(x-3)x)'*(2x-3) - \sqrt{(2x-3)^2}(x-3)x*(2x-3)'}}{(2x-3)^2}
Also you can check it by first
x>= 3/2
(x-3)x=x^2 -3x
derivative:
2x-3
Now
x< 3/2
-(x-3)x=-x^2+3x
derivative:
-2x+3=-(2x-3)
This is a lot work to do here, so I check it again with Mathematica 5.0 and it is true. But still can't see the problem.
njama said:
Hello!
I want to find
I know that
Thanks in advance.
You can't ignore the fact that there is a discontinuity at x = 3/2. The proper computation is
\left.\mbox{sgn}(2x-3)(x-3)x\right|^{2}_{3/2^+} + \left.\mbox{sgn}(2x-3)(x-3)x\right|^{3/2^-}_{0},
where 3/2^+ means infinitesimally above 3/2 and 3/2^- means infinitesimally below 3/2, such that in the first term sgn(2*x-3) = 1, while in the second it is -1. You then get
-2 - (-3/2)(3/2) - ((-3/2)(3/2) - 0) = 5/2, which is your desired result.
Thanks for the reply. I think I understand.
A_1(x)=(x-3)x when x>=3/2
and
A_2(x)=-x(x-3) when x<3/2
Where A1(x) and A2(x) represent the area of the interval [0,x]
But if I want to find the area on the interval [0,2]
Now I find the area of [0,3/2] + (area [0,2] - area [0, 3/2])
First I must find A2(3/2)+(A1(2) - A2(3/2))=A1(2)
