Can I Handle This Course Load? Seeking Advice.
Taking organic, physical, analytical chemistry, modern physics, and calculus III in one semester is considered manageable by several contributors in the discussion. Organic chemistry is highlighted as particularly challenging due to its heavy emphasis on memorization and is often seen as a "weed out" course for chemistry majors. Modern physics varies in difficulty depending on the institution and instructor but is generally viewed as interesting rather than overly difficult. Calculus III is typically regarded as the least challenging of the calculus sequence, provided foundational knowledge from earlier calculus courses is solid. The consensus emphasizes the importance of staying on top of coursework and not falling behind, with the possibility of dropping a class if necessary. Overall, the course load is deemed doable for someone with a strong academic background, especially for those pursuing a degree in chemistry.
kooombaya
Is this doable??
Next year I'm taking organic, physical, analytical chemistry, modern physics, and calc3. I guess the only way I'll know is to actually do it and see if I can handle it but I wanted to ask you guys and see if you had any thoughts about it. Plus if you've been through this some tips and advice you can give me so I don't end up failing :(
Thanks
Only you know if you can handle it; not just because you are aware of your capabilities more than anyone here, but also because you know how these classes are at your school - we don't. That being said, organic chemistry seems to be a lot of memorization and work; almost a weed out class for chem majors from what I've heard. I'm not sure about the other two. Modern physics (is this a bridge between lower level physics and upper level physics including topics from QM, etc?) is usually more interesting than it is hard, and cal III should give you no problem if you work some practice problems here and there, provided you know cal I. In a sentence, that course load will probably be a decent amount of work but definitely manageable.
Thanks
What Newtime said. It's doable. What you said minus the Modern Physics is what a 2nd year chem major would take at my school. It's a lot of work but if you don't get behind you should be alright.
Chemistries will be the hardest. Modern different from school to school, & ever professor to professor. It seems everyone has a take on what is should be, but most of them don't seem to be too bad. Calc III is usually the easiest of the calculus sequence in my opinion. But yeah, like the others have said, only you know if it's doable or not. If you've had good grades up until now, I'd try it. If you have to, dropping a class isn't so bad if you absolutely have too.
Ok thanks for the input guys, it really helps. And winowmak3r I'm aiming for a degree in chemistry hence the courses. Thanks again!
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
I graduated with a BSc in Physics in 2020. Since there were limited opportunities in my country (mostly teaching), I decided to improve my programming skills and began working in IT, first as a software engineer and later as a quality assurance engineer, where I’ve now spent about 3 years. While this career path has provided financial stability, I’ve realized that my excitement and passion aren’t really there, unlike what I felt when studying or doing research in physics. Working in IT...
