Is cos(x - (pi/2)) equal to cos(x)tan(x)?
The equation cos(x - (pi/2)) simplifies to sin(x), as cos(y) becomes zero when y equals pi/2. The original identity being tested, cos(x)tan(x), needs to be evaluated to verify if it equals sin(x). By substituting tan(x) with sin(x)/cos(x), the right side can be rewritten, leading to a comparison with sin(x). Ultimately, the identity does not hold true, as the two sides are not equal.
silversorrow
cos(x-(pie/2))=cos(x)tan(x)
I have to verify this identity and can't seem to figure it out. cos (x-y)=cos x * cos y + sin x * sin y
well since cos y = 0, it kind of eliminates that side of the equation and I end up with sinx * sin1
Did I go about this all wrong?
It is sin(x)*1 not sin 1, because sin(pi/2)=1. So far you have cos(x-pi/2)=sin(x), which is correct. Now write out the right hand side of your original equation and see what you get.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
