Compressing ideal gas isothermally, calc work
gcooke
10 moles of an ideal gas are compressed isothermally and reversibly from 1 to 10 atmospheres at 300K. Determine the work done ON the gas.
dw=-PdV
PV=nRT
dT=0
T=300K
dP=10atm
calc dV from ideal gas law = 2.27e10 m^3
so now we have dV for work eqn, but P is not constant?
Thanks.
As much as I don't like thermodynamics, it doesn't seem very complicated.
Start with claperyon equation nr. 1:
p1V1=nRT
which allows you to calculate the first volume.
Equation nr.2:
p2V2=nRT
allows you to calculate 2nd volume. Hence you've got your integrating limits.
Now, I wish I knew how to use TeX in here :/.
Anyway,
<br /> W=\int\limits_{v_1}^{v_2} pdV
As you mentioned, p is not constant, but you can, again, calculate it easily from clapeyron's equation:
pV=nRT. And then substitute p under integral with what you've got, integrate. Should get natural logarithm.
Thank you, irycio!
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
