Transfer function from amplitude response?
The discussion focuses on a method for generating a polynomial for the amplitude response of a filter, which allows for customizable flatness and roll-off characteristics. The original paper provides an amplitude response formula but lacks details on deriving the corresponding transfer function. A participant successfully determined the transfer function using a Mathematica notebook and offers to share it with others interested in trying it out. The conversation highlights the collaborative nature of problem-solving in filter design. The shared notebook could be a valuable resource for those exploring similar filter responses.
cuallito
Hi, in the paper I've attached, they give a method for generating a polynomial g for the amplitude response of a filter that gives arbitrary flatness and roll-off characteristics.
\frac{1}{\sqrt{1+g}}
And then they say the transfer function can be easily determined from this, but they don't say how.
For example, they give an amplitude response
\frac{1}{\sqrt{1+10s^{8}-24w^{10}+15w^{12}}}
and then they just say "then we will have the transfer function"
\frac{0.259}{s^{6}+2.392w^{5}+3.661s^{4}+2.755s^{3}+2.615s^{2}+1.162s+0.259}
I know how to get the transfer function from the amplitude response for a standard filter like a butterworth or chebyshev, but for ones like this?
Hey, I figured it out. I wrote a Mathematica note book that does it. Anyone want it?
Cool. Yes please, it would be fun to try out. Can you post it as an attachment?
Yeah.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
