Pully/block system on an incline
  • Thread starter Thread starter b577phaty
    Incline System
The discussion centers on a physics problem involving a block on an incline connected to a pulley. The block has a mass of 10 kg, the incline angle is 30°, and the coefficient of friction is 0.2. Participants suggest using free body diagrams and Newton's laws to derive equations for the block's acceleration and the tension in the cable. There is confusion regarding the correct interpretation of torque and tension in the equations, with one user providing a calculation for acceleration as approximately 2.72 m/s². The conversation emphasizes the need to clarify the relationship between tension and torque in the context of the pulley system.
b577phaty
A block of mass m = 10 Kg is attached to a cable that wraps around the pulley. The pulley is pivoted at the center, and the angle of incline is θ = 30°. The radius of the pulley is R = 0.5 m and its moment of inertia is I = 0.4 Kgm2. The block is released from rest and slides down the ramp, and the coefficient of friction is μk= 0.2 between the block and the ramp.
(a) Find the acceleration of the block. a = _______________________
(b) Find the tension in the cable. T = ______________________
I have no idea where to start.
1. Draw a free body diagram for the mass on the incline.
2. Use your FBD to apply Newton's Law to the mass.
3. Draw a free body diagram for the pulley.
4. Use this FBD to apply Newton's Second Law (for rotations) to the pulley. Note that the tangential acceleration of a point on the pulley's rim is the linear acceleration of the rope and, of course, the mass.
5. Steps 2 and 4 will give two equations and two unknowns, the acceleration a and the tension T.
6. Solve the system of two equations and two unknowns to find what the problem asks.
For my equation, I got mgsin(theta)-I(a/r)-umgcos(theta)=ma however this does not give me the correct answer. Any ideas?
Unless you show what answer you got and how, I have no ideas because I don't know what you did. The equation seems correct.
For the block
Fx=mgsin(theta)-T-Ff=ma
Fy=-mgcos(theta)+N=0
For the pully
T=Ialpha
T=I(a/r)
10*9.8*sin30-.8a-.2*10*9.8*cos30=10a
a=2.72 ?
b577phaty said:
For the pully
T=Ialpha
T=I(a/r)
In the above equations "T" stands for "Torque" not "Tension". You treat it as if it were tension. What is the torque τ if the tension is T and the lever arm is r?
