Work on Electricity (is this right?)
  • Thread starter Thread starter GlobalDuty
    Electricity Work
The discussion focuses on calculating the work required to assemble four identical point charges of +4.0 mC at the corners of a square with 20-cm sides. The proposed formula for potential energy is U=K(q1q2/r12 + q1q3/r13 + q1q4/r14 + q2q3/r23 + q2q4/r24 + q3q4/r34). The user arrived at an answer of 3.9 but was advised to include units in their final answer. Overall, the approach to the problem is considered reasonable.
GlobalDuty
Four identical point charges (+4.0 mC) are placed at the
corners of a square which has 20-cm sides. How much work is required to
assemble this charge arrangement starting with each of the charges a very large
distance from any of the other charges?
I want to know if this is the right formula and answer:
i got 3.9 as the answer.
Looks like a reasonable approach to me. You should get in the habit of putting units on at least the answer, though.
